Ana içeriğe geç
The first-generation Ford Focus was manufactured in Europe from 1998-2004 and in North American from 1999 to 2007.
How do I fix the clutch adustment on ford focus
how to fix clutch on ford focus
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Check the reservoir for the clutch fluid . If it's low, fill it, and then pump the clutch pedal several times to restore the hydraulic pressure in the line. The reservoir is located on the left side of the engine bay, not far from the firewall . Bleed the clutch system if filling the reservoir didn't work. As the system is hydraulic, air bubbles in the line can affect the clutch's performance. Fill the tank with clutch fluid, pressurize it, open the bleed valve that's located on the cylinder near the left side. Pumping the pedel pushes the old clutch fluid and replaces it with new fluid. You can adjust the height of the clutch pedal in your Ford Focus by looking beneath the dash to the top of the pedal. There's a knob on the pedal that you can loosen with an Allen wrench. Change the height of the pedal, test it out, and then retighten the knob on the clutch pedal. Look to the master cylinder and the slave cylinder next. If these are leaking, this might be the cause of the clutch problems you are experiencing in your Ford Focus. The slave cylinder is located near the clutch housing, on the left. Examine the pressure plate and flywheel which is located inside the clutch housing. As the clutch works due to friction, the flywheel and the pressure plate can wear over time, and no amount of adjustment or refilling of the reservoir will work.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
beet2233 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 33
Her zaman: 14,253
