Ana içeriğe geç
The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
730 Soru Tümünü görüntüle
Soru Kapandı
What Screen do I order?
I'm working on repairing an IPad but I'm not exactly sure what part to order. I looked up the model on line and I am lead to believe it is an IPad 2 (Model A1395 ). I'm not sure which screen to order. Could you direct me so I can order the part. The screen is shattered and I will need to get the repair guide for the right one as well.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi Andy! There are several variants of the iPad 2, but they all use the same replacement glass and display. If only the glass is broken, and the display beneath it is still fine, here's the part you need: iPad 2 Screen Digitizer Assembly
If the display is broken as well, you'll also need a replacement LCD: iPad 2 LCD
This guide should be all you need to get through the repair: iPad 2 Wi-Fi EMC 2415 Front Panel Replacement
Good luck!
iPad 2 LCD Görseli
Ürün
iPad 2 LCD
$59.99
iPad 2 Screen Digitizer Assembly Görseli
Ürün
$29.99
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 229
