Ana içeriğe geç
The 1999 Chevrolet Malibu is part of the fifth generation (1997-2003) manufactured by General Motors. This is the first smaller, front-wheel-drive Malibu that General Motors put back on the market after the Malibu line was temporarily discontinued in the early 1980's.
55 Soru Tümünü görüntüle
Random misfire changed the spark plugs
Sensor reads "random misfire".changed out the spark plugs worked better still really rough though.then it went back to the way it was before .sounds like it's running on 1 cylinder.this happened all the sudden.what should I do.think there was some oil in the gallery where the spark plugs go
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
If your plugs have oil in the chutes you need to change the valve cover gasket . this may be your problem but it would be nice to know what code its throwing is it a p0300 or is there a cylinder attached to the code. like maybe p0301 or another code . If there's a lot of oil it can destroy the coil-pack
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
johnhiggins174 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 9
Her zaman: 315
