Ana içeriğe geç
Duyuru tarihi - 2014, Kasım Samsung Galaxy Core Prime (G360, G361), 1.3 GHz dört çekirdekli işlemciyle güçlendirilmiştir ve 1 GB RAM ile gelir. Telefon, microSD kart aracılığıyla 64 GB'a kadar genişletilebilen 8 GB dahili depolama alanına sahiptir.
Phone is not turning on
I was browsing through net then suddenly my touchpad stopped working. Display was clear though but touchpad was not working. Then i googled about it and came to know that i have to remove the battery and press the power button for 60seconds and then place the battery back and switch it on. But after placing the battery back, The phone is not getting switched on
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
1 Cevap
Filtre ölçütü:
What was the battery percentage before it turned off? Does your battery drain fast or have you noticed anything like this before?
There might be a chance you just need a new battery. If you have owned that phone for awhile and it is the original battery - batteries eventually just need to be replaced over time. I would test to see if that is the issue.
I hope that helps.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
No the battery was like 25%, and like i said i switched it off. and then pressed power button for 60secs and then tried starting it.
tarafından
Yorum Ekle
Yanıtını ekle
Gourav Agarwal sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 1,866
