How do I fix the broken charge port?
Will not charge. The inside of the charger is broken.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Sally Daniel, the charging port is connected to a flex cable. all you have to do is replace that. No soldering involved. Flex cable is available at places like this and many others
Bu yanıt yardımcı oldu mu?
I don't think the charge port is USB, it uses a mini cord that should slip over the contact.
i think you need to resolder that USB port
go to ifixit youtube channel and check out resolder of USB port on SGS3, on SGT4 it should be the same
i don't think SGT4 has USB port on doughterboard (so you just replace that little piece )
resoldering that without equipment is nearly impossible
you can buy tools and DIY but it's gonna cost you a bit
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 803
1 Yorum
I had the same problem with device purchased May 2015. I just received replacement unit 2 days ago and again have same problem!
troyerdd tarafından
