How do I swap hard drive from a Compac to gateway desktop
Steps on how to swap a hard drive from a Compac to Gateway desktop
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Assuming it is an SATA compatible drive, remove the drive from the compact, attach it to an adapter or use and external enclosure, use your disk utility to reformat it and install a system. Drop it in.
Bu yanıt yardımcı oldu mu?
If you intend for the hard drive to run you OS then you will need to format and reload you OS after the switch. the system wont work from one to the other.it will only work on identical systems. however if you are using the hard drive for storage only and not trying to run an OS from them then simply swapping them in as an auxiliary drive is fine making sure to activate them in drive management . heres an instructional video on the hardware end
https://www.youtube.com/watch?v=5lVnFlFr...
Hope this helps
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 20
Her zaman: 270
3 Yorum
Gary Reeves Sr what model Compaq and Gateway are you looking at? Do you have a model number on either one of the hard drives?
oldturkey03 tarafından
The gateway is a dx4860-ub32p desktop, it has no hard drive. The Compaq I have to chk the model.
Gary R Sr tarafından
Compaq model is CQ5320Y
