Ana içeriğe geç
All about the X20 from Fujifilm announced on January 7th, 2013.
Optical Vieuwfinder is blur
The optical vieuwfinder is Blur only if you complete zoom out is it apears to be focused sharp, resetting the camera doesn’t work
However this does not have any influence on the foto quality
How can i fix this problem?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 5
Yorum Ekle
1 Cevap
Filtre ölçütü:
There is a linkage problem....the fix requires top plate removal....it is exactly the same procedure as the X10
there are approx 10 screws involved....it is only necessary to remove the upper connections to gain access to the innards....one major problem is the tiny 1 Torx screw at the front by the view finder.
Study the movement as you turn the lens to switch on...you should be able to see the linkage part.This sounds like it has jumped which accounts for the lack of focus at the widest angle of view.
Be aware that the lugs are plastic and not metal so tread carefully as over tightening will cause these to break.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Freddy sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 1,774
