Ana içeriğe geç
Apple iPhone 5s, 10 Eylül 2013 tarihinde duyuruldu. Bu cihazın tamiri, daha önceki modellerinkiyle benzerdir; tornavida ve plastik açma araçları gerekir. GSM ya da CDMA olarak, 16, 32, 64 GB kapasiteli Gümüş, Altın ve Uzay Grisi renklerinde mevcuttur.
Soru Kapandı
What keeps the glass attached to the screen?
I recently bought a second-hand 5S with a rear camera that wouldn't focus. I bought a replacement camera and started to open the phone with a suction cup. As I pulled, the glass separated completely from the display assembly along the right-hand side of the phone. I immediately stopped applying pressure, and it went back to normal. At this point I aborted the repair. Upon further inspection, I noticed that the upper right-hand corner of the glass has about a half-millimetre of play when I press on it.
The phone works perfectly well, and the glass doesn't seem like it's in any danger of falling out. However, I later did manage to replace the camera and noticed that a lot of dust had made it into the phone in that corner where the glass is not attached. I suspect that this contributed to the original camera failure.
There was already one bit of dust between the glass and the display, and after seeing the camera situation I'm worried about more dust getting in and ruining things. Has anyone else encountered this sort of glass-screen separation? What can I do about it short of replacing the entire assembly?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
All the cheap screens will do that when you pry the screen. You can purchase a new frame with hot glue pre install or you can just buy another aftermarket screen.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
This is the original screen, but it was loose before anything I did. What do you mean by "a new frame with hot glue pre install"?
tarafından
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 118
