Ana içeriğe geç
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
home button problem on iPhone 3G
Hi guys,
I have just a quick question if the proximity sensor does not work properly, will this affect the home button? because my home button just stop working.
Thanks very much.
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
home button connects to the top of dock connector. proximity should be ok. try opening the front display using ifixit guide, check the prongs under the home button are undamaged-should be up slightly, if not try lifting them up very gently. clean the top of dock connector. the home button gets a lot of dirt round it and under it!
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
thanks too much. this was helpful.
tarafından
Yorum Ekle
Im having sort of the same problem. I dissassembled my iphone and when i put it back together it works fine but my power button is a little further in. Ity works but i have to apply a little more pressure than usual and it does spring back up but barely. Also, my home button does not respond unless i press it real hard or i hold down on the left side of it and then press the button.
Puan 0
1 Yorum:
try checking the home button as above. the power button is tricky devil to seat properly. you'll have to take it back out and just check you've put the right screws in (made that mistake) and that it's screwed in to the right place (ditto to that mistake) also check that the silver metal ring is hanging down. it really is trial and error. if you can still get it to work then sometimes its easier just to leave as is.
tarafından
Yorum Ekle
Hi, I am having a little problem with my button, I need to make a pressure on it to work.. help please
Puan 0
Yorum Ekle
Yanıtını ekle
mohammed sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,859
