MacBook Pro Power Adapter on a MacBook?
I found out from this lovely website that my repair centre has put magsafe of a MacBook Pro on my MacBook. What could be the consequences?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
I've interchanged them for years. The only problem I've run into is using a 45 watt on one wanting a 65 watt. It doesn't charge the battery. Else wise I've experienced no problems.
Bu yanıt yardımcı oldu mu?
Don't worry. A MacBook Pro adapter won't hurt a MacBook. It might even work better, since it won't get as hot. A MacBook adapter might fail to charge a MacBook Pro, and over time, might overheat, since a MacBook Pro requires more power than a MacBook. But the other way won't cause any problems, and might end up better for you.
I forgot to mention, magsafe board not magsafe charger...so my problem is the that repair guy has put 17" 1296 magsafe board on my 13" 1278 laptop.
Kindly help
I have killed an adapter trying to power more wattage than what it can deliver. Will be fine the other way.
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 2,105
