Ana içeriğe geç
Canon AE-1, değiştirilebilir lenslerle kullanılan 35 mm'lik tek lensli refleks (SLR) film fotoğraf makinesidir.
Why does the mirror lock up after shutter is fired?
The advance lever works, and the shutter button does too, but once I fire the shutter, the mirror stays up (it's like im doing a long exposure). So I remove the 6v battery and right away the mirror drops, but then I place the battery back in and it happens all over again.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
2 Cevap
Filtre ölçütü:
I do to at slower speed settings and I wonder if it is a lube issue since I barely use this oldie..
Will post if I ever get a fix..
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Did you ever fix? Having same problem!
tarafından
Yorum Ekle
There’s a wire inside the top cover. It links the speed dial with another dial and a spring located in the left side under the rewind lever. It it’s either broken or loose (spring tension is lost or it went out from the pulleys) the speed will always go to infinity and the mirror wont come down until reseting the signal. You have to replace the wire if broken or set it tight again if its loose.
Puan 0
Yorum Ekle
Yanıtını ekle
Ana sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 33
Her zaman: 3,080
