Removing vent window pins
How do I remove the pin on vent window handle
Bu iyi bir soru mu?
Bu iyi bir soru mu?
you should remove the framework of the window so as to not break the glass then you can either replace it as a unit or drill the pin out and replace it with a roll pin later
Bu yanıt yardımcı oldu mu?
I took a long punch and ground about a inch or two down until it would fit in the hole making contact with the outside of the roll pin. With the window out of th truck very carefully tapped out the pin.
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 275
