Ana içeriğe geç
Why is my drone not flying?
It starts but won't take off?
It just flips over on the wheels and by itself it just dosent go up?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 13
8 Yorum
Mine has the same issue, its like the propellers are revered. It wont take off, it will only only push downward into the ground, its unusable!
tarafından
I have the same issue
tarafından
same issue anyone know why?
tarafından
me too it just spins backwards all by itself when you take it off on the weels for a few seconds and i think it has to do with balanced weight but at the moment im still trying to figure out whats wrong
tarafından
tarafından
3 tane daha yorum göster
Yorum Ekle
12 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The proppellers are mounted in the wrong order. Switch left and right propellers front and back. Had the same problem. The drone was pushing down instead of moving up
http://blog.parrot.com/2014/07/24/how-to...
Bu yanıt yardımcı oldu mu?
Puan 6
4 Yorum:
Hi thanks God bless you it works i thought my new drone was spoilt i came here read your started my drone and it came i recommend this to everyone IT WORKS
tarafından
hello, thank you your suggestion works
tarafından
Thanks a ton! UDAMAN
tarafından
Top man. It's working now :)
tarafından
Yorum Ekle
Two propellers angle up and two angle down. Align then in a cross cross pattern so:
front left angle up - front right angle down
back left angle down - back right angle up
Puan 4
3 Yorum:
Thank you so much. This is exactly right!
tarafından
OMG this was helpful!!! Thank you!!!
tarafından
Thanks it works perfectly
tarafından
Yorum Ekle
Keep switching the propellers and trying it until you get the correct order
Puan 2
1 Yorum:
ok thank you
tarafından
Yorum Ekle
But I figured it out one of your PROPELLERS might be WEAKER than the other ones allowing it to be UN-EVEN. For mines that's what it is but I might need to buy new propellers if you can do that
Puan 0
1 Yorum:
i bought new propellers it still doesn't work
tarafından
Yorum Ekle
yes thats all it does and dont come off the grown just flips foward
Puan 0
Yorum Ekle
My drone typhoon h is not responding to the monitor
Puan 0
Yorum Ekle
My typhoon h drone camera is nor responding to the monitor
Puan 0
Yorum Ekle
No.it goes on it's side. And doesn't fly. It's not mine. It's a friends drone I was using
Puan 0
Yorum Ekle
The wings are rotating but it doesnt fly
Puan 0
Yorum Ekle
I had the same problem. I had to put the propellers on again after a crash and I just installed them on the wrong motor. Once in the right position it works like it’s supposed to. Good Luck!
Puan 0
Yorum Ekle
Check the direction of the props. They might have gotten reversed and the 2 same angle props go diagonally to each other
Puan 0
Yorum Ekle
if you press the takeoff button then try lifting up it should work
Puan 0
1 Yorum:
my parrot rolling spider never failed so theirs should be a priority
tarafından
Yorum Ekle
Yanıtını ekle
Isaac Papasidero sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 29
Her zaman: 17,682
