Ana içeriğe geç
Can someone recover data from a smashed iPhone?
I have a iPhone 6plus that was driven over, completely destroyed! There is no throwing a new screen on it. However the internal components seem mostly intact. Can the memory be put into a dummy phone to recover pictures?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
joey, not unless you try your logic board out in a new case. You are of course going to run into numerous issues including your touch ID fingerprint scanner unless you can salvage the original button. There is no way to transfer the memory IC's to a dummy phone.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
En Yararlı Yanıt
Difficult to say without seeing it. You potentially could get this back to working, the logic board that is. My advice is to plug it into iTunes, and see what it says, first
Puan 3
2 Yorum:
There is no point connecting to itunes with a smashed iphone. The phone needs to be unlocked to sync.
tarafından
Or to save all the info. If you where signed into icloud you might be able to sign in on your new phone to the same account
tarafından
Yorum Ekle
Yeah would need to see a picture, but if you have a passcode on your phone, you will not be able to access the data, until you put in the passcode on the phone and trust the computer. If you plug into iTunes and hear the tones that's it's connected that would be good. Maybe you could find a repair place in your area to see if they could put on a screen or a broken screen for a few bucks just so you can get your data. If you need some help let me know
Puan 0
Yorum Ekle
You should check your iTunes or iCloud backup first, and then if that doesn't help, use a data recovery tool to have a try.
Puan 0
2 Yorum:
Check your itunes or iCloud backup firstly when encounter data loss.
tarafından
My iTunes won’t unstall or do update Apple say it micro sifts issue. So they did all they could n iTunes claim it Microsoft. Neither did anything to get this resolved so can’t use iTunes at all
tarafından
Yorum Ekle
It is possible to extract data of your smashed phone, if you have been constantly backing up your iPhone to iCloud, then you can restore your smashed iPhone data from iCloud backup.
The same things goes with iTunes backup. If you have kept the backup of your iPhone to iTunes then you can restore data from iTunes backup.
However, if you do not have any backup and as you said that the internal components are mostly seems intact, then you can also use third party iPhone Data Recovery software such software are specifically designed to retrieve data from smashed iPhone.
Puan 0
Yorum Ekle
Yanıtını ekle
joey sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 13
Her zaman: 23,057
