Ana içeriğe geç
Why is Bluetooth is unavailable when I check profiler?
I replaced the dc in as well as the frame around the LCD; everything was a success however when I checked the profiler the bluetooth was no longer available. My question is where is the bluetooth antenna/chip or whatever it is on this computer? I have it open but im not seeing anything that would appear to be wires I forgot to connect. Thanks for any help
Ibook G4 1.33 14" A1055
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Go to this teardown and look in the upper left hand corner for the bluetooth board and cable: http://ep.yimg.com/ca/I/lovemacs_2119_29... The cables run right next to each other in the upper left hand corner and you may have disconnected something.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
From this diagram does it look as though the antenna runs up the side of the lcd or does it stay in the upper case area?
tarafından
Yorum Ekle
Yanıtını ekle
mike36 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 911
