Ana içeriğe geç
Toyota'nın en çok satan kompakt otomobilinin 8. nesli (E110).
Why is the "Check Engine" light sometimes on?
The "Check Engine" light is sometimes on my 2001 Toyota Corolla. We went to a lot of places to fix it but still it comes back.
Can someone help, i hope to fix it soon.
thanks
Update
My corolla is 2001 I had the codes run the other day. They said It is running lean and it also blows white smoke occasionally.. we have replaced the o2 sensor up front and number four coil as it suggested running better but still blowing smoke but mainly when first starting and when it warms up. what could be the problem? we also replaced leaking valve cover gasket. we have always kept oil in it.The car seems to run better since replacing #4 coil on plug. But we want to fix the lean mixture how is this done?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
3 Yorum
I've got the same problem with my Corolla. I've taken it to a number of places and they say it's a fuel pressure issue. One mechanic recommended getting a new gas cap, which I did. No change. At this point I'm considering just breaking the light bulb because the light is so annoying.
tarafından
asdas, what error code did they give you?
tarafından
I have that problem too to my nissan urvan estate 2011 model check engine sometimes.what is the problem.
tarafından
Yorum Ekle
15 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Go to Autozone or any other major automotive parts store & ask them for a free OBD (On Board Diagnostics) Code reader check. Hook it up to the car, pull the codes & let us know. Some times you may have to drive with scanner attached if it is a intermittent problem. There may be a lot of things to suspect.
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
The check engine light can mean a variety of things. If it is not blinking it is typically related to the Emission Control Systems.
Take the car to an AutoZone, PepBoys, or any of the auto parts houses. They can plug the reader in and pull the code.
Typically it will mean;
- Gas Cap Loose
- O2 Sensors (Oxygen Sensor to determine how rich or lean the air fuel mixture is and whether the Catalytic Converter is doing it's job)
- MAS/MAF Sensor.
Anything can trigger it, it's best to have the code pulled and you can easily determine what the system is complaining about.
Puan 2
Yorum Ekle
tighten down your gas cap .check Eng. light is emissions."smog related"
watch and see if it comes on after fueling . about 10 min. down the rode .
Puan 1
Yorum Ekle
There is a very common problem with the Corolla that causes this.
It is a dirty MAF (MassAirflowSensor) and it can easily be cleaned.
There are several guides on the web, Google "Toyota corolla maf sensor". Expensive electronics cleaner is not needed, Isopropyl alchohol and a Q-tip will work fine.
You will need a scanner to reset the EngineCheckLight (Autozone or a friend) or I think it will automatically reset after about 40 times you start the car?
This is a 10minute repair. For some reason most professional mechanics do not know how to Google!
Puan 1
Yorum Ekle
valve seats needs to be replaced because when it's cold the rubber valve seats let's the only down inside the cylinder head once it warms up the rubber valve seats keeps it from smoking you need to get the valve seats replaced
Puan 1
6 Yorum:
I have toyota corolla Axio 2006 model, engine 1NZE (VVT-I). water mixed with engine oil then I decided to buy a fill kit of top gasket to replace. After replacing process was done, the engine check disappeared (went off) and could not start only cranking. What is the solution to that problem? Please help
tarafından
Why does my 1999 toyota corrolla sometimes have hard time to start and I have to spray starting fluid in the filter to start?
tarafından
What is the promblem
tarafından
What is the answer
tarafından
What is the question
tarafından
1 tane daha yorum göster
Yorum Ekle
as regards fuel issue.
your fuel pump in the tank could be failing. never run the tank to the bottom. i've heatd of leakining injectors on these models. but right now i'm rebuiling a 2002 1.8 lit., corolla. cusomer just smoked it at 160,000. if the head was bad thats $390.00. if the engine core is unrebuildable than a used, 90 day garut., engine is no less than $1,100 , and then it's still a used engine. plkese rebuild your top -end at around 100,000 miles and rebalance. timing belts on time, and note to you mech. the tensioners fail prematurely,. go to 30,000 replase, not 60,000. and completely rotate out trans. fluid at 70,000 or more. some manufact. specs are wrong , torques wrong, factory quality contrl issues . go with your gut and still aplly old school rebuild ways.. we havn't had a rebuil return in 5 years.. Kraig
Puan 0
Yorum Ekle
My 2006 Diesel VW jetta occasionally has engine light problem. Took it to VW and received some suggestions from Wolfsburg to replace various wiring. Made my own determination that after a heavy rain, traversing puddles may cause engine light to turn on. When things dry out, light goes off.
Puan 0
Yorum Ekle
For the first 12 years that I owned my Corolla, I never had Check Engine Light problems. Now I have the same problem intermittently. The Code is always the same and points to a problem in the emissions system. We replaced the gas cap and occasionally, I still have a problem. The light had not come on for many months. Then 2 weeks ago, it was glaring at me. My husband retightened the gas cap and the light went out about 50 miles later. I find this situation quite annoying. Since it has continued intermittently even with a new gas cap, I can't help but wonder if the problem lies elsewhere.
Puan 0
Yorum Ekle
Hi,
I recently bought a second hand Toyota Duet. I drove 400 kms with no problem... and then suddenly I got the engine check light on. I got the fuel filter, and air filter changed as recommended. The problem went away only to return after a few days. when the check light came on, I could feel that I had to press really hard for acceleration as I could feel a drag more like as though air is entering the engine rather than fuel. BUT on doing so the check light would go off and then only return after sometime or days.
In the morning these day, I can smell petrol when I start the car and the smell fades away when I drive. I today got the engine check light on while driving again, so took the car to the service station. The check light went off when I reached the service station, so couldn't source the codes. Funny still that on being driven by the mechanics, the car never gets that engine check light on.... and now this is really irritating me.
Puan 0
Yorum Ekle
My 2001 Corolla has been giving the same error. It seems that the technician cannot fix it as the error message changes. I have had many things changed on it. It is costing more than its worth. I think Toyota cars have this problem.
Puan 0
Yorum Ekle
I have 2000 CE Corolla 225k Miles. Engine light on. Fault code is P0171.
MAS Sensor cleaned. O2 sensor changed still E light on.
What I can do more?
Puan 0
Yorum Ekle
I have 2003 Toyota fielder; check engine light comes on after driving for a while and when i switch engine off and on again, the light is gone - quite annoying.
Puan 0
Yorum Ekle
Guys, its the CHARCOAL CANNISTER or the evap sensor that connects the cannister to the throttle body. Octane is highly volatile. The Charcoal cannister traps the volatile octane from the fuel tank and lines and supplies that to the throttle body while the driving to maximise fuel efficiency. Clogged or blocked cannister or sensor that works intermittently is what causes the Engine check light to come on and it smells like gasoline in the car for a little while when the trapped volatile octane gas escapes under the hood rather than going into the throttle. Just clean the cannister with pressurized air. That shud clear out the dust in the cannister allowing more octane gas to get stored and smooth out the pathway.
Puan 0
3 Yorum:
Sorry can you put picture of canister where it is and how it looks like. Regards
tarafından
Have a Toyota fielder hybrid WXB 2016 model The ABS light has started to come on. Please let me know what is wrong and how can I fix it?
tarafından
@robinsonrobins This question is way overloaded; please delete your comment and instead start a new question; that way people will be focused on your question and not have to pick one issue out of many.
tarafından
Yorum Ekle
at 10 years old almost all electric motors have to be replaced with brand new radiator motors ,fuel pump motor and since a transforming coil even though it has no ball barring's it has enamel on the inside windings that convert electricity to different voltage like the ignition coil and some relays electro magnetics.high temperature and more spark when opening and closing due to higher draw from electric motors.the motors always look fine but dust from the carbon brushes inside build up a short along with damage to enamel on wiring inside from sparks.to keep a car forever like i plan to do although to bad i did not know sooner,new OEM radiator fans first,new ignition coil set next and a new OEM fuel pump. The rest cleaning or replacing even the air conditioner electric motor shows high draw must be replaced.it's more inexpensive to buy only the same motor's and just change motor's if you got tools and skill.I love music in my car had to install Odyssey dry cell battery with model that has M letter in it it has a metal pan thing inside withstands high temperature more than 178 degrees installed a voltmeter wired to my cigarette lighter near my ash tray thank god now when i turn my key on i see volt of battery ,start car i see alternator volt ,run an electric feature see drop in voltage finding problems easy now.i might have saved my alternator before if i new the radiator fans draw more power when they get older than my engine starter. now i have to clean my catalytic converter almost 200,000 miles on ride very necessary .if i could go back in time i would have replaced only the electric motors of the radiator fans and the AC fan with OEM parts as for the window motors first time a piece of plastic breaks or they slow down must remove door panels clean off all old grease i use wd40 them put new grease and oils just about that 10 year mark of course i got time and money i would get to all this at 5 year mark my property gets over 140 degrees in the summer in the sun ,my driveway 156 degrees.
Puan 0
Yorum Ekle
OK 2000 Toyota Corolla CE e 1.8 check engine light RPM cluster without without RPM
Update (05/23/2019)
2000 Toyota Corolla Cee I'm looking for check engine light on the dashboard on the cluster without the RPM cluster only check engine light he has the mileage and the gauges no RPM
Update (05/23/2019)
1999 Toyota Corolla CE e I'm looking for check engine light but it does not have RPM on the on the cluster just the mileage and gauges and get gas light
Puan 0
Yorum Ekle
Yanıtını ekle
Samy sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 51
Her zaman: 69,227
