cant charge my table
I cant charge my table, do your company sell one that will fit my device
Bu iyi bir soru mu?
Bu iyi bir soru mu?
the recver end of the charger is pushed back in not allowing the power cable to make contack . it needs to be pused back in place to make contack agend.
Bu yanıt yardımcı oldu mu?
How do you pull the receiver end back out
How do you pull the charger piece back because mine is pushed back
How do I pull back out or where can I send for repair
do you have to open in up
My tablet will not charge. The end of the charger will not connect to tablet?
I am having the same problem! What is the answer?
I would like to have this uniy replaced there is something wrong this is pnly about the twenty time this has happened i am tired of this.
tablet dose not response or turn on or off
My charger wobbles when it is connected to the tablet and the charger end does not go in completely. It won't charge. What gives?
Son 24 Saat: 4
Son 7 gün: 23
Son 30 gün: 36
Her zaman: 1,749
10 Yorum
Mine will not charge, it's only 2 months old
Paul Case tarafından
Also when I try to turn it on a battery symbol with a triangle in it appears
I have the exact problem, is there a solution? Besides buying a new one.
Yvonne Cowan tarafından
I am also having this problem, getting very frustrating!
lulalor68 tarafından
Mine and my daughters will not turn on either and both are only 3 months old!
Carlo Stokes tarafından
5 tane daha yorum göster
