Ana içeriğe geç
Digital Pocket Memo with slide switch operation.
7 Soru Tümünü görüntüle
Why is the screen on my DPM frozen?
Since I dropped my DPM from about five inches, the screen is frozen. When I turn it off and on the device starts with the same screen. I switched the BA-slider and could listen to my recordings, so I believe the problem is caused by the display, right?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
My DPM8000 just froze up with lit screen as I was preparing to use it to transcribe
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
As you already figured out there is not much of an uncertainty that the source of your problem is the display. First of all you should check the plug connection between display and logic board. If the connection just came loose or undone you simply need to plug it back in. Otherwise you will have to purchase an exchange display. We recommend to have an additional look at the Troubleshooting Page for any other causes.
For disassembling and replacing please refer to the provided guides.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Ecodesign TU Wien sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 16
Her zaman: 923
