Ana içeriğe geç
Samsung B1445A, Samsung tarafından üretilen yüksek verimli bir önden yüklemeli çamaşır makinesidir.
loud knocking on spin cycle
Hello. When our samsung front load washer gets to the spin cycle it sounds like horses are galloping through the laundry room. It is under warranty. They replaced shocks....just as bad or maybe even worse. If you are in the room it's so loud you can not hear a person talk beside you. I read a few of the other questions of similar nature on here but didn't see on where shocks had already been replaced and checked that not clothing or foreign objects in machine. I video recorded the sound when I turn drum by hand. The bang happens when you move the drum so simple to reproduce the noise. The tech seemed stumped so I thought I'd ask professionals online. Thank you for any ideas.
Bu iyi bir soru mu?
Puan 6
10 Yorum
My samsung washing machine 16.okg .once it come to spin d drum inside make a lot of noise like dancing...can someone tell me what to do pls
tarafından
It’s the spider arm that’s attached to the bottom of the tub. Major defect that’s happened to so many people.
tarafından
Samsung washers and warranty are lousy. My drum is out of round! The machine pounds like crazy. Cost $80 for a service tech to come out and tell me it cannot be repaired because the drum, shaft, motor are all integrated. I'm very upset and will avoid Samsung in the future. Drum ought to carry industry standard 10 year warranty. Not Samsung.
tarafından
I also had this same problem. I replaced the spider arm, both bearings and seals and all four shocks. It still does the same thing, on medium spins it wobbles so bad it bangs the side of the cabinet. I replaced the shocks because I noticed about a 1/2 inch free travel with no resistance on them. Upon getting the new ones I noticed the same thing. So they must produce them with that play. Machine is dead level some loads it’s not as bad but never did it before.
tarafından
My door literally bangs back and forth during spin cycle. Can anyone tell me how to tighten the door so it stays sealed. If I press on it it stops it. It is literally the door not being tight enough. Please help.
tarafından
5 tane daha yorum göster
Yorum Ekle
6 Cevap
Filtre ölçütü:
Seçilen Çözüm
Most Frequent Causes for Washer is making loud noise
Cause 1
Tub Bearing
The tub bearing is mounted in the middle of the outer tub. The tub bearing helps to keep the inner tub spinning smoothly. Replacing the tub bearing is a very involved repair and will require disassembling most of the washer. If the tub bearing is defective, we recommend replacing both the outer tub and bearing as an assembly if the manufacturer offers the components together.
Cause 2
Tub Seal and Bearing Kit
The tub bearing is mounted in the middle of the outer tub. The tub bearing helps to keep the inner tub spinning smoothly. If the washer is noisy during the spin cycle or is leaking from the bottom of the tub near the transmission, the tub seal and bearing are likely defective. Replacing the tub bearing is a very involved repair and will require disassembling most of the washer. If the tub bearing is defective, we recommend replacing the outer tub and bearing at the same time.
Cause 3
Rear Drum with Bearing
The rear drum has a bearing or bearings in it to keep the inner tub spinning smoothly. If the tub bearing system is defective the washer can become very noisy. On some machines bearings are sold separately from the rear drum, however we recommend replacing both the outer drum and bearing as an assembly if the manufacturer offers the components together because removing and pressing in the new bearing can be exceptionally difficult. Be aware that replacing the outer tub and bearing is also not easy and can be very costly.
Bu yanıt yardımcı oldu mu?
Puan 4
8 Yorum:
Where do I get replacement?
tarafından
Lawrence www.repairclinic.com
tarafından
It is a bolt loose on the bracket that holds the drum and shaft that connects to the belt drive wheel. You have to take out the whole drum casing and open it undoing all the bolts. Also remove the centre bolt on the belt drive wheel its glued in and remove wheel the inner drum will seperate. The drum bracket will be slightly loose. Check the three bolts holding the bracket Use a good lubricant before attenpting to tighten as the loose bolt can snap.
Goodluck
tarafından
Hie l have a problem with my sumsang front loader. It broke that 1 piece in the drum. Sorry l don't know what it's called. But it's the 1 that prevents clothes from tearing. How can l glue it back.
tarafından
Is it better to get new washer or replace what price r u looking at to replace tub and bearings i have same problem mines 4 yrs old and prolly not in warranty ty
tarafından
3 tane daha yorum göster
Yorum Ekle
The main bearings are bad cousins the tub to be out of balance. This is a very common problem. New shocks will not fix this problem, you need a new washing machine. Or the whole tub assambley replace. The tech that replaced the shocks ether has no idea what he's doing or just wanted to get payed and ripped you off or warranty company.
Puan 3
1 Yorum:
My washer every single time it gos to drain and spin cycle is thrashes around and ends up moving and hitting the wall. What can i do to get it to stop that?
tarafından
Yorum Ekle
The answer is the spider arm flange attached to the back of your tub. This is repairable. Search Youtube.
Puan 3
1 Yorum:
I am work in samsung home applience customer care center today i go to check 1 samsung front load 6 kg washing machine the machine is very noisy before 1 month i change the barrings of tub know the washing machine is cycle very hard and make bad noise any one solve this problam .....i want help
tarafından
Yorum Ekle
I had a knocking noise at fast speed and found it easy to fix. My model is Ecobubble wf11.
I took the back and top of the machine and spun on spin mode and watched. on top of the drum casing behind the PCB was a black box, i assume to hold the drum against the lid of the machine. While running I noticed the 2 bolts holding it down had come lose and the box was banging against the drum casing that it should be attached too.
In my case there should be 3 bolts 1 was missing and 2 had come lose. After tightening the bolts with a 10mm hex driver it was fixed. The machine had been shipped with 1 bolt missing. Maybe it is shipped with 2 bolts, but it is clearly designed for 3.
To fix this problem turn off the wall power and just take off the top of the machine.
Hope this helps someone. I always try to fix myself if out of warranty.
Good luck and watch utube videos if you are unsure.
Dez
Puan 2
1 Yorum:
thank you bro, i just did what you said. it worked
tarafından
Yorum Ekle
Hey Graeme.
You said your washer was still under warranty. My advice would be to avoid doing anything that might void the warranty. This would include taking on troubleshooting and repair aspects independently. I would report the continuing problem to the manufacturer (or entity issuing the warranty) and request they honor the terms and conditions stated in the warranty. Whatever the problem turns out to be, your liability and cost, etc., is minimized, this way.
Good Luck.
Puan 2
1 Yorum:
His comment was 3 years ago, I added to the thread in case anyone was looking for solutions.
tarafından
Yorum Ekle
for me it was a broken spider - had corroded in 6 years of light use. Crap product IMJ
Puan 0
4 Yorum:
Yup. Same for here. Bought a brand new pair and have them 45 days and the brand new washer has the same %#*@ issue.
tarafından
My Samsung clothes washer is making a lot of noise while spinning and when the timer goes to 9 , it jump up again to like 16. Doesn't wring close.
tarafından
Same issue. Gonna try open her up and she what's what
tarafından
Buyer beware, spider bracket failure on our 3 month old washer.
Samsung has been knowingly selling these cheap faulty washers for at least 16 years .
tarafından
Yorum Ekle
Yanıtını ekle
Graeme Elsom sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 15
Son 7 gün: 80
Son 30 gün: 391
Her zaman: 216,612
