RAM configuration in bank/slot iMac late 2015
Sorry, I have heard that the procedure may has changed.
I want to add 2x8GB RAM to the exisitng 2x4GB (Bank 0 and 1/DIMM O = slot 1 and 3 from the bottom).
I may be wrong, but I was told to use the same amount of RAM/memory in each channel/bank, 12 in each, instead of same RAM.
the pristine configuration (4GB Slot 1 and 4GB Slot 3 - iMac Late 2015) would validate this (regarding to dual channel).
What is the correct configuration?
Thanks a lot.
BANK 0/DIMM0:
Größe: 4 GB
Typ: DDR3
Geschwindigkeit: 1867 MHz
Status: OK
BANK 0/DIMM1:
Größe: 8 GB
Typ: DDR3
Status: OK
BANK 1/DIMM0:
Größe: 4 GB
Typ: DDR3
Status: OK
BANK 1/DIMM1:
Größe: 8 GB
Typ: DDR3
Status: OK
Bu iyi bir soru mu?
