Ana içeriğe geç
Xperia Z1 Compact, Sony'nin üstün özelliklere sahip kameralı telefonudur. Xperia Z1 modeline benzer ancak daha küçük ve daha ekonomiktir. En önemli özelliği 20,7 megapiksellik sensörüdür. Piyasaya sürüldüğünde mevcut renkleri beyaz, siyah, pembe ve limon yeşiliydi. Bu cihaz, model numarası (D5503) kullanılarak tanımlanabilir.
Screen not working after replacement
Hello I have Xperia Z1 Compact with a broken screen. I have ordered a replacement screen from ebay. When I connect the screen to the phone and turn it on, nothing happens. I know that the phone works because I hear boot up sound. Also when I press unlock button and then volume up/down keys I can hear the volume change sound. If we assume that the replacement screen is working, what could be wrong with the phone? Is there anything I could do to fix it?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum
I have a similar problem, i tested the new screen and was satisfactory, however after installing it with the gasket it failed to fire up
tarafından Paylaş
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The LCD ribbon cable could have been damaged during installation. Make sure the lcd connector is connected prperly. You might have a defective part, eBay parts are not always the best choice....
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Thanks for the answer. Unless the ribbon was already damaged I doubt I damaged it. Connector is easy to access and I was gentle. I was wondering what chances are there that there is something wrong with the phone itself. For example that metal panel below the display (is that heatsink?) seems a bit detached now. Could a connector itself be a bit detached from the board?
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Ivan Savu sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 1,363
