Ana içeriğe geç
A1418 / EMC 2833 / Late 2015 / 3.1 GHz Core i5 or 3.3GHz Core i7 Processor. Released October 13, 2015.
96 Soru Tümünü görüntüle
Can an iMac have a dual SSD?
Hi hi at all,
I have a iMac with fusion drive, my question is, can I replace the HDD for a SSD? i.e. can the iMac have two SSD?
Thank you.
Update (01/14/2016)
Thanks, but, to add the SSD sata for de HDD, have I to break the fusion drive (SSD pcie)? two SSD (SSD sata and SSD pcie of the fusion drive) can be in a Imac or not?
Is that break the SSD of fusion drive is much more difficult that only change the SSD for the HDD.
Bu iyi bir soru mu?
Puan 0
1 Yorum
Correct! You will need to break the Fusion Drive set and leave the SSD drives independent. Which is also a good reason to go with the external solution. You can not have a dual SSD Fusion Drive set. A dual SSD would confuse the OS which is why it won't work.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Yes, you could exchange out your SATA 2'5" HD for a SSD.
Be aware the 'Thin Series' iMacs are a bear to open and you could damage the display in the process if you are not careful!
Frankly, I would recommend instead getting an external Thunderbolt SSD/HD setup. It will be faster than the internal SATA port. The other option here is to break the Fusion drive set and make the SSD your boot drive only having your OS on it.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Mac sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 414
