Ana içeriğe geç
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
wifi greyed out and bluetooth keeps spinning
My iphone 6 wifi greyed out and bluetooth keeps spinning, wasting valuable data, everything else works, I recently replace my digitizer and glass and now this. I reset everthing, rebooted phone to original from itunes, maybe I left something loose, any suggestions or help.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
3 Cevap
Filtre ölçütü:
That means the wifi/Bluetooth flex has been damaged and needs replaced. I would replace it after factory resetting your phone first.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
If Wi-Fi is greyed out (can't turn on) it is more likely a board issue (could be software but unlikely). Usually the Wi-Fi ic chip going bad.
tarafından
Yorum Ekle
I have the exact same problem, just got the flex ribbon, and am attempting to replace now. Wish me luck. Question, how can you tell if the antenna also needs to be replaced? I would rather not crack this open twice.
Puan 0
Yorum Ekle
Did anyone have Luck With this I have an iPhone 6 With the same Problem
Puan 0
Yorum Ekle
Yanıtını ekle
wayne sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,428
