Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Repair guides and support for the laptop line of Acer's Aspire series for casual home and business use.
932 Soru Tümünü görüntüle
new laptop is slow / unhappy with performance
Acer aspire es1-512
New Acer Laptop with Windows 10. I've downloaded all available updates and disabled any obvious processes running which I don't need. However I'm still disappointed with the start up time and slow load time of programs. Is there anything I can do? Ive never used Windows 10 before, not sure if its a resource hog compared to Win 7 or not. I have Intel N2840 CPU and 4 gig RAM.
Thanks for any suggestions.
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 5
Yorumlar:
The Intel N2840 processor is very simply a low powered budget CPU. You will not get great performance from it. An SSD will somewhat help speed up loading . You don't say how much RAM you have but the single stick can be removed and replaced by an 8GB one.
Blocking Microsoft's telemetry software could help a little. Making sure W10 is updated also helps some. Run Windows Update. Updating drivers helps. I use IOBit's Drive Booster free version.
It is nothing to do with Acer it is the Intel processor. I have the ES1-411 which is even slower. We use it for travel as it is very thin and light weight. For heavy duty use I use an HP business laptop which is very fast and built like tank.
Windows 10 actually is faster than the other versions of Windows. It works much better with the hardware. I have W10 running very nicely on a 12 year old HP desktop with a single core AMD Athlon processor.
Good luck.
tarafından
It says 4 gig RAM right at the end of the post. Duh
tarafından
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
Just a few suggestions.
1. Have you checked that 'fast startup' is enabled?
http://www.tenforums.com/tutorials/4189-...
2. Have you checked in Task Manager/ Startup to see what programs are loaded on boot?
http://www.pcadvisor.co.uk/how-to/window...
3. Have you turned off (the ones you don't want) Windows live tiles to stop them 'updating' unnecessarily. It cuts into your download as well as using the CPU.
http://www.howtogeek.com/223254/how-to-a...
4. Have you turned off Windows Defender if you have another AV installed?
5. Have you disabled any unnecessary 'bloatware' installed by Acer?
6. There was a BIOS Version update to Ver.1.15 dated 13/08/2015 which simply says "Improve System Performance' You may wish to check your BIOS version. Here is a link to download the update http://www.acer.com/ac/en/GB/content/dri... select BIOS/Firmware tab
Bu yanıt yardımcı oldu mu?
Puan 3
Yorumlar:
hi Jayeff,
Thanks for the suggestions. I already have 1.15 bios and Defender already turned off. Fast start already enabled, but this must be a misnomer, it doesnt seem very fast to me.
#3 Is one thing I haven't done, so I'll check into that.
If you can think of any other tricks specific to Win 10, let me know.
tarafından
Hi,
The only thing that quickly comes to mind is to 'disable' fast start up (I know it sounds counter-intuitive) and turn off your laptop in the normal way (Do not use the restart option this one time) . Then turn it on. Hopefully it will be faster. Have read and also heard that this worked and when fast start was re-enabled the boot time sluggishness had disappeared. It somehow seemed to 'reset' the fast startup mode.
http://www.windows10update.com/2015/05/w...
tarafından
Got mine yesterday 4/11/17 slow slow and slower 3 finger shuffle found 65 processes running at first Boot up updates took 3.5 hours to complete. Got that pee ed off turned it into a frisbee off to get a Mac
tarafından
Replace hard drive with SSD.
tarafından
Yorum Ekle
I had a similar problem with my new acer, I went to the microsoft storeapp and found a lot of the pre-installed apps had been downloading/updating so I went to settings>system>apps and uninstalled a bunch of them. Restarted the laptop and no problem!
Puan 1
Yorumlar:
Hi my Acer aspire 3 A311-31 is lag. The screen stopped for more than 30mins. This laptop is new and i use this for 3 days now. When i opened my facebook acc and used youtube, it stopped. How can i solved this?
tarafından
Yorum Ekle
I also have the same problem and loathe my laptop and acer in general now .
I gave up on it and luckily didn't really have to use it up until now, and I'm close to setting it on fire . I don't have an answer for you sorry. just posting in hopes I'll get a notication when someone else comments and has a definitive answer on how to fix this piece of sh#t laptop
goodluck
Puan 1
Yorumlar:
Did u try installing different operating system work?
tarafından
Yorum Ekle
Try to buy 8gb of Ram, much better
Puan 0
Yorum Ekle
I also have this same issue, brand new Acer aspire 3, a9-9420, 8gb RAM. Since my first day booting up it has been extremely slow. I have a 7+ year old dell that runs smoother. I have tried everything, including ran multiple tests on the harddrive and RAM. Everything is very sluggish and laggy. Last thing i have to try is a clean install =/
Puan 0
Yorumlar:
i dont know what to do anymore. I have a new aspire 3 A314-41-983d. I also have upgraded its ram by 8 GB But i got a lag playing fallout NV. What is happening @#$$%. My old Laptop MSI Core i3 HD graphic 3000, 4 GB RAM is better than this. I am so tired of this.
tarafından
Have you gone to the ACER website and entered your device serial number, SNID or model number and upgraded ALL drivers and BIOS?
tarafından
Yorum Ekle
Yanıtını ekle
fierosrcul sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 58
Son 7 gün: 423
Son 30 gün: 1,836
Her zaman: 51,836
