Ana içeriğe geç
Machine turns on, no signal / video output?
I have an xbox 360 that has never red-ringed and turns on just fine, but refuses to work with any TV I try to plug it into. I have plugged another xbox 360 into the same cables and TV, but when I plug this one in the TV reads "No Signal."
Any thoughts??
Bu iyi bir soru mu?
Puan 12
1 Yorum
I need help on the same 360, needs laser replacement but its something else now, i go to turn it on and it does but dont fully boot up, tried switching to a different setting but shows no display, whats the problem, its from 12-04-2006 and its the Xenon model with AV cable only, tried the cable on my Jasper model from 2-18-2009 and it worked so idk
tarafından
Yorum Ekle
7 Cevap
Filtre ölçütü:
Seçilen Çözüm
Make sure that the component cable is set to whatever input you have the cables plugged into. For example, if you are using the component connection, RED-GREEN-BLUE and then WHITE-RED for your audio, make sure the switch is set to HDTV. If you are using standard connection, YELLOW-WHITE-RED, then make sure it is set to TV.
If this still doesn't work, try a different pair of video cables and if the same results are coming up, you will need to have the board repaired. You can not just replace the motherboard either or you will not be able to play games on the system, make sure to have the actual board repaired.
Yes there are ways to repair the board out there but board repairs are different from replacing it. If you don't use the right equipment, you pose a greater risk of damaging the board more than it is already. It's best to have the system repaired by a professional that provides a warranty on their work.
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
Who has switchea on cables its not the 70s try again
tarafından
Yorum Ekle
En Yararlı Yanıt
on the video cable, there is a switch that changes between hdtv and standard definition tv. make sure it is on the right one.
Puan 3
Yorum Ekle
This is caused by a heat up of the chips internally and you will need to stop this. The actual chip that is overheating here is the scaler chip or the display chip on the back of the Xbox 360.
Puan 2
Yorum Ekle
If nothing works wrap a blanket around the Xbox while still it's on it will get very hot when it shut it off An back on with hdmi cable on it should work I had to do it for mine
Puan 1
Yorum Ekle
https://www.youtube.com/watch?v=EvFq9-py...
Puan 0
Yorum Ekle
Myxbox turn on, and no signal,everybody please help me, i put 3 wire hdmi and its same. or can i buy the RCA cable?
Puan 0
Yorum Ekle
I've got the same problem
The power is reaching the xbox and i have the green lightturning on but without any image pn the screen
When i took it to the repair shop i was told that the motherboard is blown and there was no solution to that
Puan 0
1 Yorum:
Green lights means systems and components are OK. The repair shop told you your motherboard was toasted so they could buy your console for peanuts, repair it themselves and sell it 200$ easy money, 30 minutes repair, 200$ for the shop.
tarafından
Yorum Ekle
Yanıtını ekle
Hal sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 37
Son 30 gün: 154
Her zaman: 92,890
