Ana içeriğe geç
The Mazda Millenia is an executive car produced by Mazda, a Japanese automaker, between 1993 and 2002.
I would like to know if there is a resistor
2001 mazda millenia. I am not getting power to my fuel pump. I have checked the relay, even bought a new one. I would like to know if there is a resistor. dealer says that there is not one. online says there is one... where is it located?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
albert enstin there is no separate resistor other than the one in the relay. Since you already replaced the relayI'd suggest you check to ensure that you have power to the fuel pump relay.
Fuel Pump Resistor and relay (Speed)
Inspection
1. Disconnect the fuel pump resistor and relay connector. Measure the resistance between terminals A and B by using an ohmmeter
Specification:0.38-0.42 ohm
2. If not as specified, replace the fuel pump resistor and relay (speed).
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Hi,
Hey OT03 I'm confused by your answer given that you have posted this for a same year range model fuel pump fuse location
tarafından
jayeff, you are absolutely right. Reading the original answered, I confused myself. It should have read that there is no separate resistor. Hope the edit clarified it a bit. Thanks jayeff.
tarafından
Yorum Ekle
Yanıtını ekle
albert enstin sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 596
