Ana içeriğe geç
An 11.6" touchscreen tablet and a Full HD laptop by Sony. It was released in 2012.
22 Soru Tümünü görüntüle
Sony Vaio Duo 11 DC input needs replacing
My Vaio Duo 11 fell onto the floor. Unfortunately it landed on the DC input side. When I checked the internal battery will not charge. And I think the DC input broke as I opened it up and see the DC input board was bit loose. At the moment I can only use the laptop using sheet battery, it only lasts 1-1.5 hours usage. And I have to take the sheet battery off for recharging (inefficient process) . I wonder if you could tell me where I could buy the Sony Vaio Duo 11 DC input board from? Thank you
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum:
Hi,
Just looking on Ebay brought up a lot of hits for a DC power jack/cable. Unfortunately none when you searched for 'Sony Vaio Duo 11' but a lot which had Sony Vaio model numbers one of which may be your particular model. Maybe you can look and see if you hadn't already done this, that is. Also found if you enter your model number followed by 'parts' into google there are numerous places offering parts for Sony Vaio laptops. Knowing the exact model number really helps. As I don't know your model number I can't pinpoint a source (close or not) for you.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
hey, I think it is hard to find this input power jack board for Sony Vaio Duo 11, I found someone is selling the input jack, you will need to solder it to the original board, check this page: http://www.dcincable.com/sony-vaio-duo-u...
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
the dc connector board is not connected by any screws and is held in place by the LAN port and the groves on the connector. The input jack in the link is the right one.
tarafından
Yorum Ekle
Yanıtını ekle
Ady sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 1,182
