Ana içeriğe geç
HP Compaq Presario C700 için onarım bilgileri ve sorun giderme. Bu cihaz, 2008 yılında Compaq Presario dizüstü bilgisayar serisinin bir parçası olarak üretilmiş, uygun fiyatlı bir dizüstü bilgisayardır.
Scam preventing access to files/documents
My computer has been scammed and i cannot access my files/documents..
message says the files have been been protected by a strong encryptioin with RSA-4096 ..
I understand this is a scam that has been going for a few years...
What can i do ???
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Mary is there two problems ? the overheating power adapter and the ransom ware . As for the power adapter how hot is it and does it get that way when you first turn it on or does it take some time to heat up? Does the computer seem to run hotter as well ? Does it seem to be harder to plug in to the laptop?
The ransom ware is an ongoing problem that is a hard fix . The fixes that are out right now are not that effective and can end up with you loosing all your info. what I would suggest to you is buying a new hard drive and having a new OS installed ,start fresh and setting the old one aside until a fix is found to rescue you info safely. If there was not any important data on the computer or you were smart and had it all backed up, you can just reformat it and that will wipe the drive clean and a new fresh OS can be installed. At this point in time there is no safe fix that can guarantee getting your info back
Hope this helps
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Yanıtını ekle
Mary Brigg sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 27
Her zaman: 405
