Ana içeriğe geç
Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
154 Soru Tümünü görüntüle
Wifi button greyed out
I replaced the screen and after awhile the wifi button cannot be activated, should I replace the motherboard?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
No, you will probably just have to replace the wifi antennas, which is probably what got ripped when you opened the device.
Bu yanıt yardımcı oldu mu?
Puan 2
3 Yorum:
I agree, everyone who has worked on iPads enjoyed one day or another a teared up wifi antenna ;)
tarafından
Yup. Happens when you put the pick too far in on the right side.
tarafından
What I'm afraid of is the wireless controller being messed up. That would be a board-level repair.
tarafından
Yorum Ekle
Sounds like you didnt reseat the wifi module properly, or as you were dismantling it you cracked part of the ribbon cable.Check , reseat, or replace the wifi module.
I assume you tried doing the cold reset and switching in amd out of airplane mode, this is usually a fix for airplay too when that “greys” out.Hope this helps.
Puan 1
Yorum Ekle
Replace your wifi antenna iPad 3 Wi-Fi Wi-Fi Antenna Replacement
Puan 1
Yorum Ekle
Yanıtını ekle
Eric Wayne sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 212
