Ana içeriğe geç
Repair guides and support for motherboards and CPUs.
My motherboard is causing my computer to shutdown every 30 minutes.
My motherboard is causing my computer to shutdown every 30 minutes.. It is not from any other hardware and has nothing to do with software. What can be causing this? Please help.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
5 Yorum:
what type of motherboard and what makes you so sure its a motherboard issue are you getting any error messages. Mac or PC
tarafından
It is a Z77. I have tried removing all the hardware (except power supply and RAM) and the problem continued. It is a PC. No I am not getting any error messages. Windows.
tarafından
AS Rock LGA1155 DDR3 SATA3 USB3.0 Quad CrossFireX and Quad SLI A GbE ATX Motherboard Z77 EXTREME4 http://www.amazon.com/LGA1155-CrossFireX...
tarafından
Is it overheating? What indicator lights do you get when it powers down? How long before you can restart?
tarafından
If you know it isn't the software or other hardware, you should have the answer already. I would still suspect other hardware such as the cpu cooling fan. If it has stopped or is not running at proper speed or there's a lot of dust in the heat sink, that could cause the system to shut down.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
If your computer refuses to boot or tends to turn off without warning, see the Faulty Power Supply to Motherboard problem page for possible causes and solutions.
Whether you have disconnected all the boards and the problem persists, it seems to be a Power Supply (PSU) issue. Try to isolate completely the PSU and check the voltage. If it raises and suddenly cuts, the PSU has a bad component. I have experienced such an issue: when a component driving the tension output is bad, the current raises too much, and upstream the system detects a short.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Mert YILMAZ sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 1,794
