Ana içeriğe geç
Kasım 2006'da Kuzey Amerika'da piyasaya sürülen Wii, hem çevrimiçi oyunları hem de Wii Shop Channel üzerinden oyunların ve medya uygulamalarının dijital dağıtımını destekleyerek internet bağlantısını doğrudan destekleyen ilk Nintendo ev konsoludur.
Fix cracked wii remote front
I cracked the wii remote front infrared panel while bowling, now it doesn't point. Can this be fixed? All other functions are still working.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 4
Yorum Ekle
5 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The tri-wing needed to open your remote is also available in iFixit's driver kits.
[bağlı ürün eksik veya kapalı: IF145-022]
[bağlı ürün eksik veya kapalı: IF145-028]
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
tarafından Paylaş
Yorum Ekle
You can try just unscrewing the case and removing the front cover and see if that helps. The front cover is just a filter that only passes infrared light (and keeps dust out). But if you damaged the sensor inside, then you'll need a new Wii remote. To unscrew the case, I believe you need a tri-wing screwdriver, which you can get at Ebay. If the sensor is damaged, you can sell the remote to a hacker who only needs it for the accelerometer.
Puan 1
Yorum Ekle
This is what I did to my remote and it works perfect http://howtofixstuff.blogspot.ca/2013/08...
Puan 0
Yorum Ekle
The front of the wii remote had a cracked screen because my older sister or brother and me were playing just dance 1 2 3 or 4 she or he kept on hiting it out of my hand. XD is that your problem.
Puan 0
Yorum Ekle
Follow a guide for your wii remote, but before that, make sure you buy a replacement case/screen.
Puan 0
Yorum Ekle
Yanıtını ekle
Val sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 26
Her zaman: 6,882
