battery will not charge.
i have a g 4 the power cord was tripped over and pulled and the charging receptor in the computer may have been damaged. battery will not charge
want to open computer and fix.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
The most likely problem is your DC-IN port. We need to know the Exact model you have to direct you to the correct part and repair manual. Remove the battery and look in the compartment as most Books have this information in there.
Bu yanıt yardımcı oldu mu?
thanks for reply/serial yd6050baswz/ refurb BPg4 15/1.67.1x512/80/sd-dl/apx/at- usa
Here's the part: [bağlı ürün eksik veya kapalı: IF154-108]
Here's how to install it: ere's how to install it: PowerBook G4 Aluminum 15" 1.67 GHz DC & Sound Card Replacement
all procedures followed and ok until the last. the rj11 cable and square piece is not on replacement part! there is just a space on replacement part. what do i do next? does taht piece get rmoved from old part and attached to new? or is part wrong?
no worries i fixed it. its working!! thanks very much/ doug
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 1,016
2 Yorum
awesome ! thanks for the help and info. will let you know how it goes.
d
doug tarafından
hello/ please see my latest comment from today. something different in replacement part? computer apart. waiting for help?
doug tarafından
