Unable to recongnize SSD through SATA connector
Hi guys!
So I just replaced my HHD with a solid 240GB Hyperx Savage from Kingston and something funny is happening. I am able to create the OS partition and clone my HHD into the SSD and when conected through the USB port, my Mac recognizes it. However, when using the SATA connector, it just loads the apple icon bar and stalls forever....
I've tried the trim thing with the Sensei app and I've also tried to install El Capitan from the Recovery mode. None would work. Same problem all the time. I read there might be a compatibility issue with Macs mid 2009 and I'm just thinking this could be affecting the mid 2010 as well?
Any ideas would be welcome....
Thanks!!
Bu iyi bir soru mu?
4 Yorum
System specs: MacBook Pro 13" 2.4 GHz Core 2 Duo (Mid-2010)
Dan tarafından
SSD specs: Kingston Hyperx Savage
Dan tarafından
Hi Dan,
Thanks!! But, is that a no no on the SSD? I mean, not sure where exactly I have to look to see the compatibility...if any.
lsmaria tarafından
Hi guys.
I have the same problem with my MacBook Pro (mid 2010) and HyperX Savage SSD.
Did you change your data cable? Did it help you?
Sergio tarafından
