Ana içeriğe geç
iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
Why will it not turn on?
Hello. I am about to purchase an Apple iPod Classic 6th Generation in order to fix it and sell it on EBay. The seller says that the back is very scratched up (no dents) and it will no turn on. Why could this be? Could it be because the battery is broken and needs to be replaced? Thanks and please help me!
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
It could be a collage of problems. Anywhere from the battery, to issues with the logic board
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
En Yararlı Yanıt
See the concept of "Pig in a Poke": https://en.wikipedia.org/wiki/Pig_in_a_p...
You might have better luck with a "Mystery Box", http://www.ebay.com/sch/i.html?poi=&adpo...
Puan 4
Yorum Ekle
I'd be wary of any nonworking iPod you buy off eBay. I recently purchased a (supposedly working) logic board off there and lo and behold! It's giving me all sorts of headaches trying to get it to work with my iPod. The person could easily have cobbled together a bunch of nonworking parts after salvaging a bunch of broken iPods. There could be damage they're not telling you about (from water, dropping, previous amateur attempts at repair).
It sounds like the problem is the battery, but it COULD be the logic board being broken at the place where the battery's cable connects to it.
You can order it, but make sure you can return it and get a refund just in case & check out the internal parts quickly to assess the damage so you return it in time.
ALSO: if it's simply that the battery is dead, the iPod should still turn on when it's plugged into a computer or a USB to outlet converter. If it doesn't, it's not just the battery, in which case I'd be very wary. Replacing a logic board would cut severely into potential profit. Ask for pictures from the seller to verify their words if you haven't already.
Puan 0
Yorum Ekle
Yanıtını ekle
Luke Thompson sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 178
