Ana içeriğe geç
Apple iPhone 5s, 10 Eylül 2013 tarihinde duyuruldu. Bu cihazın tamiri, daha önceki modellerinkiyle benzerdir; tornavida ve plastik açma araçları gerekir. GSM ya da CDMA olarak, 16, 32, 64 GB kapasiteli Gümüş, Altın ve Uzay Grisi renklerinde mevcuttur.
3530 Soru Tümünü görüntüle
Charging port repllacement from ifix it looks different
I was looking to buy the charging port replacement for my iphone 5s, but it looks different from the one i have currently any suggestions? it seems to be missing the mounts to screw the home button connector down
Update (02/07/2016)
there
Bu iyi bir soru mu?
Puan 0
1 Yorum
[image|752610] the one next to where you connect the home button on the left
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
If you mean the silver plate that is under the connector for the home button, you have to remove it off the old one and put it on the new one. :-)
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
is it glued on the bracket? im having a tough time removing it and dont want to break anything
tarafından
Yes, it is adhered with double sided adhesive, heat it up a little bit and remove with a thin metal or plastic spudger.
tarafından
Yorum Ekle
Do you have pic to understand which mount you are talking about?
Puan 0
Yorum Ekle
Yanıtını ekle
davidschoenberger1010 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 112
