Ana içeriğe geç
One gallon wet/dry vacuum manufactured by Shop-Vac, with catalog number: 2021000 and model No. MC150A.
There is no suction in my Vac
When I try to use my vac today, I turn it on, but there is no suction.
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Most Frequent Causes for Vacuum cleaner won't pick up, no suction
Cause 1
Air Filter
The air filter traps particles as the air travels through the vacuum cleaner. If the filter is clogged, the vacuum cleaner will not have proper suction. If your vacuum filter is clogged, refer to your owner’s manual for cleaning instructions.
Cause 2
Exhaust Filter
The exhaust filter traps particles as the air travels through the vacuum cleaner. If the filter is clogged, the vacuum cleaner will not have proper suction. If your vacuum filter is clogged, refer to your owner’s manual for cleaning instructions.
Cause 3
Vacuum Hose
Remove the hose from the vacuum cleaner, stretch out the hose so that it is straight, shine a bright flashlight into one end of the hose, and look through the opposite end of the hose. If the flashlight beam is not visible from the other end of the vacuum hose, this indicates that the vacuum hose is clogged or obstructed.
Bu yanıt yardımcı oldu mu?
Puan 6
1 Yorum:
Apart from clogged filter, verify the position of the float (item 10 of your manual - a ball) inside the filter housing. If it moves up and close the motor bottom support (item 9 of the manual). The float prevents water from entering the impeller If it moves up by suction and locks no suction or blower operation is possible Tap it lightly and allow it to float freely and assemble filter unit and all other parts in position Now operate vacuum cleaner, it will work
tarafından
Yorum Ekle
My vac master beast 5.5 gallon stop working I took it apart and the power wire was off hook it back up but have a.new filter and it still not sucking what could be the problem .do you think the wire crossed up . But it comes on.the blower side works but the suction side don't.
Puan 0
1 Yorum:
tarafından
Yorum Ekle
Yanıtını ekle
Kailiang Chen sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 17
Son 30 gün: 73
Her zaman: 53,864
