Ana içeriğe geç
Coolpix S6800, 12x optik zum ve 24x dinamik ince zum özelliklerine sahip, ince ve Wi-Fi uyumlu bir fotoğraf makinesidir. Ayrıca 1080p tam HD video kaydı yapabilir ve bu videoları uyumlu cihazlarınıza anında aktarmanıza olanak tanır.
memory card is write protected?
I keep getting the write protected code when I put in a memory card. I have tried three different card and get the same message. I have locked and unolocked all three memory cards and still get the message. I have even put scotch tape over the lock unlock area (read about this on you tube). Nothin works. need help.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Take out the card. Switch ON the camera - will probably say "Out of memory" or similar. Switch the camera OFF. Replace the card, hopefully should now be OK
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
my memory card (sandisk 8gb) has a 'lock' switch on the side of the memory card. Slide the switch to the 'not locked' position and re-insert into the camera.
tarafından Paylaş
Yorum Ekle
Hi, I recently purchased a Nikon 6800 coolpix camera from Ebay. After a few weeks I though I would try it out. (Note I had an old Nikon-6800 with all of the attachments, but the screen had got a spot on it, etc), that is shy I bought a replacement camera.
New Nikon Camera: I decided to see if it would take a picture. ~~~~ it took 2 pictures, and then the camera screen said "No Memory") So I opened the memory slot and there was no memory card, (Thank you Mr. Seller) These 2 pictures looked fine. Note however, when I hooked the camera up to my MS computer to down load those 2 pictures, the computer did not see the camera.
Luckily I had 32g old memory stick (memory stick was NOT locked) that I must have used on my old camera; so I put that into the new camera.
My computer now saw the New Nikon 6800 Camera.
So I decided to go take some more pictures of the flowers, and when I tried to do itm the screen showed, "No Memory". Note this is with the memory card in the camera.
Now that old memory stick had 11 old pictures on it and I was able to down load those old pictures from the new camera with memory onto my computer, but not the 2 new pictures I just took of the flowers. Note also, these 2 New pictures did not show as being on the memory stick, even though they did come up on the camera screen Nikon 6800 new camera when one looked for old pictures on the camera.
Baffled on what to do???? Please help
Puan 0
Yorum Ekle
Yanıtını ekle
David sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 25
Her zaman: 1,535
