Ana içeriğe geç
Canon EOS 300D, 6,3 megapiksellik giriş seviyesi bir dijital tek lensli yansıtmalı (DSLR) fotoğraf makinesidir.
Why doesn't camera recognise a memory card is inserted
Camera is not writing files to the cf memory card and is saying a card is not inserted.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
maybe contacts are greasy. try to degrease it, any white spirit/alcohol will do. also, you might need to format/reformat the memory card using camera...
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
I've also discovered that this happens because of a bent pin in the camera where the CompactFlash card plugs into the camera. Mine has been the two pins closest to the eject button.
Puan 0
Yorum Ekle
This can also be caused by a defective/broken CF door switch
Puan 0
Yorum Ekle
Could it be for any other situations, as I have done all checks and keep the problem.
Puan 0
Yorum Ekle
Yanıtını ekle
Rob sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 2,901
