Ana içeriğe geç
Repair and disassembly guides for GE Microwave ovens.
Why does Sensor panal malfunction
Panel resets all the time it comes up with close door and select food setting after unplugging unit from a.c. I can reset clock and get it to work once then the panal will revert back to close door and then ask to select food type 1-6. What needs to be done
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
3 Yorum:
edroberts43 you said that "after unplugging unit from a.c." does that mean you unplug it after using it? I am a bit confused by that. What model is your MW?
tarafından
After the microwave malfunctions iIunplug the unit and I then plug it back in and am able to reset the panel my microwave is a G E s/n JVM172QP1WW
tarafından
After you plug it back in then you get the error? Or do you get it after you set the time etc. and run it once? Have you consider that it is a faulty door switch?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Maybe falty power cord.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
@wesly how would a faulty power cord cause this error?
tarafından
I don't understand how a faulty cord would make it not work or reset or nothing works
tarafından
Yorum Ekle
Yanıtını ekle
edroberts43 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 1,181
