Ana içeriğe geç
Apple iPhone 5s, 10 Eylül 2013 tarihinde duyuruldu. Bu cihazın tamiri, daha önceki modellerinkiyle benzerdir; tornavida ve plastik açma araçları gerekir. GSM ya da CDMA olarak, 16, 32, 64 GB kapasiteli Gümüş, Altın ve Uzay Grisi renklerinde mevcuttur.
3530 Soru Tümünü görüntüle
Only accepts certain chargers and drains battery quick
Hi,
I have a 5s that was returned by a customer. Originally he bought it and messaged me saying it was completely dead, I went to his house and tried a different wire and then he told me to change the battery anyway as it was draining fast. I changed the battery and the same thing happened again except the other wire didn't think this,
I disconnected/reconnected the battery and it turned on (with 80%+ battery) so I am thinking maybe it wasn't connected right.
Now I have the phone back and I have refunded him and I am doing more tests. The phone doesn't charge with certain chargers, I have a 5c that charges with all of them. I'm unsure of which are genuine and which aren't but I believe it won't charge to genuine ones
The battery drains fast in standby mode
Is this damage from using 3rd party chargers? What can I do to fix?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
What apps does he use on his phone? Have you checked charger port if there's any build up of dust / debris? If there is, use a toothpick to clean out the charger port, because if the lightning charging cable does not plug in fully into the port, some chargers will not charge properly.
It's surprising that sometimes a blocked up charger port can actually cause a phone to short and drain power.
For example, on a samsung phone, it would brick the software because pins were probably bent and shorting on boot when the charger port was blocked. Once I cleaned it up I had to reload the firmware (software / operating system) on the phone to get it working.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
The phone has been reset with no apps. The charger port is clean
tarafından
Yorum Ekle
Yanıtını ekle
James Carter sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 6
Her zaman: 250
