Ana içeriğe geç
333 MHz işlemcili 4,3 inç geniş ekran LCD. Model Numarası PSP98510. Bu cihazın onarımı için standart tornavidalar ve ayırma aletleri gereklidir.
PSP 2000 battery external charging
Can you help me my PSP 2000 can't detect any type of battery
I have the original battery but I think it died already, because it's old, when i plug the original battery it just blink orange light then green light, alternate then the orange light will be gone.
My psp only turns on when plugged in via charger, I tried using other psp batteries (brand new class a) so I plugged in the battery, it has the orange light a sign of charging but still it won't recognize by psp, the battery information says (battery external) and the other information are blank
I can use my psp/play games when plugged-in via charger no other problems except the detecting of the battery.
PSP 2000 japanese model
5.50 Prome-4
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Hi Nikko,
I've got the same issue. If you confirm that the battery you are referring to works on other PSPs, you may follow the link below. Hopefully we'll find a solution ;)
PSP working with power supply but functioning batteries not detected
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Nikko Mallari check the “Charging Fuse” If it does not show continuity and may need to be replaced, your battery won’t be found. Also check for bad traces on your circuit board as well as burned, loose or missing components around the power IC. To check it out use this SM with all the schematics you will need Psp-2000-Service-Manual.pdf
Puan 0
Yorum Ekle
Yanıtını ekle
Nikko Mallari sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 24
Her zaman: 1,098
