Ana içeriğe geç
Sony’s 20.1 megapixel camera designed to capture still images and video recording. Model number: DSC-W800.
Why will my device not power on?
Why won't my Sony Cyber-shot DSC-W800 power on? When pressing the power button nothing displays on the screen and the device seems to be unresponsive.
Could this be a battery issue or something more serious that would require repair?
Bu iyi bir soru mu?
Puan 1
2 Yorum
يرجى توضيح أكثر هذا قليلا
tarafından
@tcampo what happens when you do replace the batteries? does it then turn on?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
There may be several reasons why your device may not be powering on. Following are the common ones:
  • The battery may not be sufficiently charged. It may discharge automatically if not used over a long period of time. In this case, simply charge the battery. Also, check to make that the battery is inserted in correct orientation.
  • The battery terminal may not be clean. You may clean the terminal with microfiber.
  • External temperature also effects the way the camera functions. Thus, make sure to not use the camera when the temperature is above or below 0-40° C. Condensation might occur if the camera is moved from extremely cold temperature to a warm environment, which could prevent the camera from functioning properly. In that case, let it come to room temperature and allow the condensation to evaporate naturally.
  • For more information, refer to the troubleshooting page.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Yanıtını ekle
Thomas Campo sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 13
Her zaman: 1,543
