Ana içeriğe geç
Ryobi P202, Ryobi One+ serisinin bir parçasıdır. Bu model, 18 voltluk kablosuz 1/2 inçlik bir matkap olup parlak yeşil ve gri renktedir. Matkabın üst kısmında yerleşik bir seviye göstergesi, iki vitesli bir anahtar, yön anahtarı, manyetik tabla ve matkap ucu klipsi bulunur.
Drill will run for only a few seconds
When you pull the trigger the drill only runs a short time and stops. Releasing the trigger and re-pulling it does nothing. If you release the trigger and switch direction, then pull the trigger it run but again only for a few seconds.
Bu iyi bir soru mu?
Puan 4
1 Yorum
Hi I have the same problem.I'm thinking bushes.I'll look later and let u know bro
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Battery is most likely dead. Try charging it,........ . Test it using a multimeter. The batteries can go bad and they will no longer accept a charge.
Bu yanıt yardımcı oldu mu?
Puan 1
4 Yorum:
The battery can be easily tested using a multimeter ,check voltage before charging, then fully charge the battery , then check to see if it has correct voltage after charging,
tarafından
This is not very helpful ,the batteries are fully charged and the batteries work fine in other Ryobi tools.
tarafından
Mark Day, yeah i absolutely right with you ,
My problem is with a cordless drill 18V ..
Its worked for a few seconds atleast 3 or 5 second then become off but the battery are fully fine
tarafından
I have the same problem with my 7.25" circular saw, my drill and router. All having the same issue, with new batteries. Seems Ryobi tools start dying after about 4-5 years.
tarafından
Yorum Ekle
I did find if you unplug the battery, you reset the thermal protection, and it will run for a bit longer but still shuts down. Once it heats up you need to let it cool down for 5 minutes or so.
Puan 0
Yorum Ekle
Yanıtını ekle
Paul Moad sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 18
Son 30 gün: 48
Her zaman: 11,505
