Ana içeriğe geç
2.26 or 2.4 GHz / White plastic unibody enclosure
645 Soru Tümünü görüntüle
Soru Kapandı
Getting 4SNS/1/C0000008: Ts0P--124 error
hi guys,
My A1342 Macbook 7.1 Unibody (mid 2010) I got this diagnostic error code:
Its probably palm rest temp sensor related. Any idea where it is located / how to fix it?
Thanks in advance
Kris
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Here's a good write up on the error codes: How to invoke and interpret the Apple hardware tests
So if we dissect your error: 4SNS/1/C0000008: T s 0P--124
  • 4SNS - System sensor
  • T - Temperature
  • s - Palm rest
So yes you likely have a palm thermal sensor failure! The cause is likely liquid damage seeping under the trackpad or keyboard. Double check the Trackpad connection on the logic board if that doesn't help. You'll need to replace the trackpad.
Bu yanıt yardımcı oldu mu?
Puan 2
6 Yorum:
Hi Dan, thanks for the info but i've tried 3 different trackpad cables with the same result - error remains still.
tarafından
Not good ;-{ Sounds like you have liquid damage either the keyboard or the logic board will need attention.
tarafından
I've replaced keyboard already (after liquid spill) but for some reason power on button doesn't work and to turn it on (after shutdown) need to short keyboard connector pins on the logic board...is there anything what can i do? for now, using MacFanControl to slow fan down
tarafından
Did you find any spillage on the logic board?
Are you sure you replaced the keyboard with the correct version?
tarafından
well, didn't see anything strange on logic board and keyboard was listed as for this model of Macbook
tarafından
1 tane daha yorum göster
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 1,112
