Ana içeriğe geç
Model No. A1367 / 8, 16, 32, or 64 GB capacity
20 Soru Tümünü görüntüle
Soru Kapandı
iPod not turning on and screen popped out
one of the connectors on my ipod got disconnected and the iPod isn't turning on at all, i tried pushing it in and i think the connector is the LCD connector
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Screen popping out on mobile devices is usually due to the battery inflating and pushing the whole display assembly up.
You can simply push the plug at the top right under the screen to reconnect the LCD cable back in if you can. Use home button and power button hold for 10 seconds to hard reset the phone. If you see the apple logo, your LCD is still working. If you don't, you may need to get your LCD replaced and also get the battery checked to see if it's expanded.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Put the screen flat down on a flat surface (like a table) and push on the back till it snaps in place. I did that with mine (popped out at top right corner) and it worked.
Puan 1
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 140
