Ana içeriğe geç
The Microsoft Surface 2 was manufactured by Microsoft Corporation and is the second generation of Microsoft tablets. It was launched on October 22, 2013 and includes features such as upgraded processing power and screen resolution.
31 Soru Tümünü görüntüle
Soru Kapandı
What to do when the battery is draining too quickly?
The battery in the Microsoft Surface 2 is draining too fast. The battery expectancy is said to be 10 hours when fully charged but dies much quicker. What to do in order to prevent the the battery from draining so quickly and how to maximize the efficiency of its life span.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Battery estimates vary widely depending on what you are actually doing. 10 hours is probably not "normal use" but some utopian fantasy.
If you want to make your battery last longer, turn of unnecessary services like Bluetooth, wireless, close applications which update regularly (like Mail) and close any applications or web browser tabs that you're not actively using.
Batteries also degrade over time, so it also matters how old is your device?
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
First, make sure your device has the latest updates.
If your battery life is shorter than expected, check to see that all unused applications are not running in the background. While not using your device, make sure that you use a minimal amount of the battery off by putting it into sleep mode.
Puan 1
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 6
Her zaman: 114
