The hammer follows the Slide forward when fireing
How do I fix this problem?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Follow along with this teardown and look for missing parts, loose pins, broken pieces, etc.
I'm not sure how the pistol will shoot with you're described problem, but look thru this and see if you can find something. Good luck.
Bu yanıt yardımcı oldu mu?
This can be caused by several different things, ranging from damage to the sear or hammer spur to worn leaf spring to a bad trigger job. If you could provide more info I could help more.
Hi Darrel,
Follow down is most likely caused by negative sear engagement and/or not enough sear engagement. I recommend taking it to a trusted gunsmith to have it fixed. Shameless plug, I am a gunsmith at J&G Gunsmithing, so you can contact us about sending it in for repair. Let me know if I can be of more help.
check out the hammer and sear engagement notches; if all looks like no one has messed with it, replace the sear/disconnector/grip safety flat spring. Then test with two rounds in the magazine until it proves itself.
Son 24 Saat: 0
Son 7 gün: 16
Son 30 gün: 31
Her zaman: 736
