Ana içeriğe geç
The April 2014 update of Apple's 13" MacBook Air features refreshed dual-core i5 and i7 processors, plus slightly increased battery performance.
313 Soru Tümünü görüntüle
HELP!Near the SD card reader pole SMD specifications
Near the SD card reader have a smd inductance ,who can help me make sure it's specification ,
Its position as illustrated
... Thanks
更新 (2016年03月04日)
It was gone this is mca air A1466
as illustrated
Bu iyi bir soru mu?
Puan 1
2 Yorum
Are you using hot air or just soldering iron for those jumpers?
And why did you need them to begin with?
tarafından
because the original disappeared
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
@chenyuchih it is a bit difficult to identify exactly which component you are pointing to. A image straight down somewhat zoomed out would work better. Right now it looks like the component you are pointing to is L4400 which is a 47NH-1.3OHM inductor in a 0402 package
Bu yanıt yardımcı oldu mu?
Puan 2
3 Yorum:
thanks for your answer ....thank you very mach...when I back home I will take a picture then could you answer me again please
tarafından
@chenyuchih thank you for the additional images. It verifies that the component is L4400.
tarafından
Thank you very mach ,
tarafından
Yorum Ekle
Yanıtını ekle
chenyuchih sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 152
