Ana içeriğe geç
28 Temmuz 2014'te piyasaya sürülen Samsung Galaxy S5 mini; 8 MP arka kamera, 720p ekran, parmak izi okuyucu ve suya dayanıklılık özelliklerine sahip bir cep telefonudur. Büyük kardeşi Galaxy S5'e göre daha büyük bir ekrana, artırılmış pil kullanım süresine ve güncellenmiş bir kameraya sahiptir.
S5 Mini Screen issue "Shows static"
Hello,
I just replaced the entire Lcd/Glass/touchpanel with a new kit. Everything went fine until I switched on the device. Everything seems to be working OK :
- Phone starts up
- Welcome sound
- Is recognized and reachable via USB connected to PC
However the screen does not function correctly. It is like static on an old TV set. (See picture) I tried several times to gently press on the screen connector and such but no difference. Any ideas ? Many thanks for your help !
Tony
Resim
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Had this issue once with a HTC One M8 new screen. Turns out it was faulty. Luckily your phone isn't damaged as this has also appeared on a Samsung Galaxy S3 when it's charger port was changed using the heatgun method.
Almost certain the screen is at fault as the phone still functions, just the screen not working.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Hello Ben, thanks for the reply. That is what I suspect as well. However I saw some other posts on internet saying it was a badly attached connector. I repetedly removed and inserted the one but same result so yes probably the display is faulty.
Kind Regards,
Tony
tarafından Paylaş
πως το διορθωνουμε αυτο το ποβλημα?
tarafından Paylaş
Yorum Ekle
it could be the screen.. but i also had issue with one.. the fault rather tends to be a software issue... i was brought back to normal by flashing (not factory reset).
Puan 1
2 Yorum:
how do i fix this problem?
tarafından Paylaş
by flashing it with Odin
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
tonyknors sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 25
Her zaman: 2,263
