Ana içeriğe geç
Apple iPhone 5s, 10 Eylül 2013 tarihinde duyuruldu. Bu cihazın tamiri, daha önceki modellerinkiyle benzerdir; tornavida ve plastik açma araçları gerekir. GSM ya da CDMA olarak, 16, 32, 64 GB kapasiteli Gümüş, Altın ve Uzay Grisi renklerinde mevcuttur.
3530 Soru Tümünü görüntüle
Phone dies at 20%
I recently got a used iPhone 5s from my aunt. It is running iOS 9.2.1 and everything works fine exept for the fact that the phone will die with 27%, 25%, or 20%. When I plug it back in to charge the phone turns on again with the same battery percentage as it had when it died. Is this a software or calibration issue or do I need to replace the battery?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
i had same issue with my 2 years old phone, at 30% it will totally shut down, what i did is i replaced the battery, now everything is perfect. i used the ifixit battery replacement kit
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
I would try putting the phone in DFU mode and updating/restoring it.
Let the phone die and then charge to full
If it happens again the battery needs replacing
Puan 0
Yorum Ekle
Usually happens when you don’t charge your phone often or the common one, the battery may be old or not working. You can charge it to full and kill it again over and over til it works.
Puan 0
Yorum Ekle
Yanıtını ekle
Vince Parisi sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 16
Her zaman: 5,757
